Home > Technical (L405) > Ride quality -16 SDV8 AB |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
i agree with Mark..
9th Aug 2023 9:15am |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1129 |
A nice add-on here for a well-sorted L405 should do the job! overfinch modified |
9th Aug 2023 9:26am |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 648 |
I have Aljo, moved half a ton of plastic in the back and it was a tad better with the weight in the back. |
11th Aug 2023 8:51pm |
Just had one of my partners family members in the car and she commented:
12th Aug 2023 5:41pm |
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 |
The thing is, is that they *are* still a good ride compared with a lot of normal cars, so it was probably did feel good to your family member.
8th Sep 2023 2:23pm |
you still not happy with the ride then MW? ... - .- -.
8th Sep 2023 2:27pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3193 |
When mine came down off a 4 post lift yesterday it was noticeably less 'crashy' over road bumps at slow speeds. Something internal happening to the shocks when they are fully extended for a while? 2012 TDV8 Vogue (L322) |
12th Sep 2023 1:50pm |
OKPAULIE Member Since: 26 Feb 2023 Location: Oklahoma Posts: 2 |
I had a new compressor, valve blocks, shocks and tires and have been chasing the same issue as you. Horrible ride after all of this. I cannot figure it out and it is driving me mad! Perhaps there is a common calibration file causing this? |
12th Sep 2023 5:44pm |
Had an adaptive dynamics error code from a front suspension height sensor which would pop up intermittently. Bought a new one but when I came to replace it noticed the plug was not properly seated so after blasting it out with wd40 and pushing it in and out a few times I got it to lock properly and have not had another fault code since. Also noticed the ride is less crashy and softer at low speeds. Wonder if any resistance in the sensor circuit is enough effect the signal but not enough to throw a fault code? 2012 TDV8 Vogue (L322) |
5th Nov 2023 5:38pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
Plausible … I believe the damping rate is in part changed in response to how fast the rate of change is in the suspension moving. If the sensor arms were sticking / stiff and their movement had stiction and was stuttering, then that would pulse fast rates of change … which might affect the damping rate applied. V8 or else ... |
5th Nov 2023 6:50pm |
I was refering to electrical resistance due to a poor contact in the plug and not mechanical resistance although the latter is possible. 2012 TDV8 Vogue (L322) |
5th Nov 2023 8:38pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
Evening all.
12th Nov 2023 7:56pm |
The lack of harshness has continued on mine. So much so I'm thinking it may be a bit soft at speed and an indicator the shocks are showing their age which is unsuprising at 165k miles . 2012 TDV8 Vogue (L322) |
27th Nov 2023 6:03pm |
Faulkie Member Since: 03 Feb 2024 Location: Wiltshire Posts: 1 |
MariannaWestminster Hi I’m new to the group but joined to get some help on ride quality on my (new to me) 19MY 2020 Vogue SDV6 at 23000 miles. I’ve just part exchanged exactly the same car as a 17 MY on 22” wheels which had an excellent ride. Smooth as silk. The newer 2020 car on 21s is exactly as you describe yours with a jiggliness through the body especially at speeds above 50mph. I had the rear wheels balanced and they were very very slightly out but it made no difference. The wheels are all in perfect condition. Tyres are continentals which I don’t particularly like and the fronts are down to about 4mm. Steering is perfect. Have you got any further with correcting your issues? |
3rd Feb 2024 10:37pm |
