![]() | Home > Maintenance & Mods (L322) > D3S bulb osram upgrade |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2661 ![]() ![]() |
Upgrade the high beam fill-ins instead. |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 176 ![]() ![]() ![]() |
Hi
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1688 ![]() ![]() ![]() |
@Balloonengineer:
Ennoch Member Since: 26 Dec 2015 Location: Scotland Posts: 109 ![]() |
After clouting a deer with my 335XD necessitating the fitment of a new adaptive HID headlight it was noticeable that the new light was brighter than the original on the other side which at the time was just over five years old. I fitted the upgraded OSRAM D3S bulbs for about £120 and it made a good difference even over the new OEM (also OSRAM) bulb and a very good difference over the aged one. The light was clearer, the spread wider and the throw definitely better too. If you drive a lot at night I'd say they're well worth the spend. |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 229 ![]() ![]() ![]() |
I’ve got Philips X-tremevision gen2 in mine, can’t fault them at all. |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
Firstly- hello mr balloonengineer- I’m the one you sold the tow electrics to on eBay, thanks for that, secondly- getting back on topic I’ll be interested in any improvement as I’m not all that happy with the ones in mine either 2009 (2010 MY) 5.0 Supercharged Autobiography
See this:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35656 ![]() ![]() |
i found the headlights a bit pants on my westie so i replaced the OE 4300k xenon bulbs with fairly cheap ebay 6000k ones and slightly adjusted the beam up a bit...
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 118 ![]() ![]() |
I've just fitted a pair from Amazon (£30) and no canbus errors which is nice
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Hi,
@paul, its in the workshop manual.. |
Thanks Stan, downloaded
UPDATE: I still wasn’t happy with the Osram Nightbreaker “220%” ones, so upgraded to higher power white D3S LEDs, which are way brighter and give a good beam cut-off pattern; had them in a few months now, and not been flashed once. I got mine from AE for peanuts, I’ve posted a link on here somewhere. Not sure about longevity yet, but at the price I paid, happy to swap them out every Winter if need be. ![]() |
The lamps I took out were 35w, the ones I put in were 55w and although I have only tried them on the drive tonight, they look like a massive improvement. Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
