![]() | Home > Off Topic - Other Cars > Range Rover 2017 SPORT SVR L494 sos limited functionality |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1318 ![]() ![]() |
What permanent DTC code do you have? 2018 SE SDV8 4.4 Byron Blue |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
You will probably be better off on ;
da3533 Member Since: 08 Mar 2023 Location: London Posts: 8 ![]() ![]() ![]() |
Unnecessary quote removed
not sure. before i take it in to get this done at a price, i wanted to change the first easiest thing first which is the batteries.... |
The first easiest thing to do is do a DTC check 2018 SE SDV8 4.4 Byron Blue |
Will do.
No
i have never removed the previous owner.. Might have to go in to dealer and get them removed....
it is a bit silly to subscribe to make it work again, clear the message. Maybe one doesn't want it! Should be able to clear the warning without committing to a 2 yr thing. |
Hello
