Home > Technical (L405) > KVM & Keys - Washed key!
NZRR
New Zealand 2016 Range Rover 5.0 SC V8 Fuji White
Hi, I have a single key but want to add another to my 2016 L405. I have bought a new KVM module from John Craddocks as my one is locked. I have both GAP IID and SDD tool but I am unable to configure the new module. I have went through the SDD "add a new module" but it fails immediately and wont allow me to even commence the process. Any recommendations? I am using SDD V165? Thanks!
Post #713616 9th Mar 2025 5:38am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
You did start with the original kvm in place and then changed it out to the new one when prompted? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #713624 9th Mar 2025 9:16am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
diesel Dave wrote:
Try PD Auto Locksmith, He’s Called Paul and is based in Yorkshire, worth the travel if he can fit you in. He did mine on a 2016, removed the KVM and re flashed it together with new key. He also removed the key that was lost in my case from the KVM, all has been good since. He charged me just over £200 but that was three years ago. Not sure how far he travels but he came out to Stockport to sort mine out. He also specialises in JLR.
Another vote for Paul at PD Auto Locksmith. I can't recommend him highly enough.
Just been over to Huddersfield this afternoon with a 2017 car that has had the security mod done. Patrick at GAP said as the KVM has been locked by JLR, the only option was to replace the KVM. JLR themselves ageed with this and were quoting £1500 for a new key (£71.97 for the cut blade, £222.36 for a new fob, £234.72 for a new KVM, £453.57 for a new BCM, £300 for programming, all plus VAT). Even a local auto locksmith was quoting a similar sort of figure.
Despite the hassle of removing the KVM (as the car is an Autobiography so has the extra aircon where you need to get a socket to remove it), Paul removed the KVM, programmed a new key to the KVM, plus cut a blade for the same sort of price diesel Dave was charged.
 Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #714255 17th Mar 2025 5:37pm
