![]() | Home > In Car Electronics (L322) > Denso Navigation ROM Drive |
Yep, they're stored in the Nav. unit. You can try reloading the software if you can find a bootloader disc. |
Mudskipper Member Since: 08 Jun 2022 Location: Leicestershire Posts: 8 ![]() ![]() ![]() |
Hi Phoenix, thanks for the reply, is this the bootloader file YIA500010.iso you talk about |
Yep, that's the one - it won't update your bootloader as it's likely an older version but it should force a reload of your existing firmware, which may cure your issue. If not, there are plenty of 'for parts only' units on fleabay that have defective disc drives but the main board is OK.
Thanks for the input Phoenix, I'll burn a disc and give it a go failing that I'll get another unit of the bay as you suggested, thanks. |
