Home > In Car Electronics (L322) > Denso Navigation ROM Drive |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Yep, they're stored in the Nav. unit. You can try reloading the software if you can find a bootloader disc. |
27th Feb 2023 8:18pm |
Mudskipper Member Since: 08 Jun 2022 Location: Leicestershire Posts: 8 |
Hi Phoenix, thanks for the reply, is this the bootloader file YIA500010.iso you talk about |
27th Feb 2023 9:30pm |
Yep, that's the one - it won't update your bootloader as it's likely an older version but it should force a reload of your existing firmware, which may cure your issue. If not, there are plenty of 'for parts only' units on fleabay that have defective disc drives but the main board is OK.
27th Feb 2023 9:34pm |
Thanks for the input Phoenix, I'll burn a disc and give it a go failing that I'll get another unit of the bay as you suggested, thanks. |
27th Feb 2023 9:59pm |
