Home > Maintenance & Mods (L322) > Fuel Burning Heater fault code
DrRob
Anybody else had this? I have searched 😉
Has been working fine and warming up the interior very toasty and now it doesn’t.
Suspect the pump has gone?
 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #657736 25th Feb 2023 2:48pm
Rob, i think it could be your pump [ or lose connection?]
https://www.fullfatrr.com/forum/post582894.html
Post #657738 25th Feb 2023 3:18pm
DrRob
Cheers Stan. Will report back when solved Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #657743 25th Feb 2023 3:54pm
DrRob
Pump being swapped out this week for a new Genuine part. Will update soon to complete thread for future forum benefit 🙌 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #658787 7th Mar 2023 6:27pm
DrRob
All fixed. If you have this code then swap out the small coolant pump on side of the FBH Thumbs Up
Part number JJK000010
I’d avoid Genuine and go for an OEM to save costs Thumbs Up
https://www.ebay.co.uk/itm/Water-Pump-for-...635-2958-0 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #659074 10th Mar 2023 9:08pm
Hanwellfields
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Zermatt Silver
Congratulations on the fix. And you can make use of the FNH with the return of this wintry weather. Thumbs Up Current: L322 2011 Zermatt Silver TDV8 Vogue SE, MB GLB AMG35, Renault Clio R200 Cup
Previous: Audi RS4 Avant Nogaro, Audit TT Sline, BMW M3 E92, BMW Z4 3.0i SMG, Macan GTS, Boxster S 986, Touareg V6 TDI
Post #659222 12th Mar 2023 6:56pm
Ukandrewf
i've had this same issue with the aux water pump and warranty wise are quibbling over why the pump failed. if it's mechanical they cover it. --
On my third Full Fat RR
Post #708884 11th Jan 2025 8:12pm
