![]() | Home > Maintenance & Mods (L322) > Fuel Burning Heater fault code |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4325 ![]() ![]() ![]() |
Anybody else had this? I have searched 😉
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
Rob, i think it could be your pump [ or lose connection?]
Cheers Stan. Will report back when solved Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Pump being swapped out this week for a new Genuine part. Will update soon to complete thread for future forum benefit 🙌 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
All fixed. If you have this code then swap out the small coolant pump on side of the FBH |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 246 ![]() ![]() ![]() |
i've had this same issue with the aux water pump and warranty wise are quibbling over why the pump failed. if it's mechanical they cover it. --
