Home > General > L322 width mirrors folded |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7800 |
21st Feb 2023 7:01pm |
EOD Steve Member Since: 13 Feb 2023 Location: Lincoln Posts: 221 |
Thanks for your message.
21st Feb 2023 7:03pm |
Bloody hell… 3mm spare each side then….
21st Feb 2023 8:38pm |
New garage door then £££££ |
22nd Feb 2023 10:18am |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
One question, How do you get out then?. |
22nd Feb 2023 10:27am |
The current door is fixed such that it takes up some of the access width. A new style door fitted behind the access recess will increase the overall access width or 'drive through' space to 2300mm, an increase of 260mm, allowing much wider vehicles access, including FFRR!!!!!!!!
22nd Feb 2023 10:36am |
PS............the inside space is way over 3m wide.... |
22nd Feb 2023 10:37am |
No problem then. I wouldn't like to push a Rangie in & out of the garage |
22nd Feb 2023 10:58am |
Floopy Member Since: 28 Jan 2023 Location: Chichester Posts: 81 |
Put some ramps down and drive through the opening on a slight angle? 2006 L322 Vogue SE 4.2 |
22nd Feb 2023 11:22am |
