![]() | Home > General > L322 width mirrors folded |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
EOD Steve Member Since: 13 Feb 2023 Location: Lincoln Posts: 221 ![]() ![]() ![]() |
Thanks for your message.
Bloody hell… 3mm spare each side then….
New garage door then £££££ |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
One question, How do you get out then?. |
The current door is fixed such that it takes up some of the access width. A new style door fitted behind the access recess will increase the overall access width or 'drive through' space to 2300mm, an increase of 260mm, allowing much wider vehicles access, including FFRR!!!!!!!!
PS............the inside space is way over 3m wide.... |
No problem then. I wouldn't like to push a Rangie in & out of the garage |
Floopy Member Since: 28 Jan 2023 Location: Chichester Posts: 82 ![]() ![]() |
Put some ramps down and drive through the opening on a slight angle? 2006 L322 Vogue SE 4.2 |
