Home > Technical (L405) > Aftermath of a misfuelling... |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1776 |
SDV8 recovered in recently, as a non start
17th Feb 2023 8:52pm |
That is your last line of defence against bits of the HP fuel pump getting into the cylinder bore and scoring them...
17th Feb 2023 10:56pm |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 |
Great diagnosis and explanation. visiting from www.rrsport.co.uk |
18th Feb 2023 7:51am |
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 |
As above, thanks Chris
18th Feb 2023 7:56am |
That is the end of the fuel rail PRV
18th Feb 2023 8:02am |
FWIW, this is what was drained from the tank
18th Feb 2023 8:07am |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
I'm going to go out on a limb and suggest a backyard attempt at washing red diesel gone wrong. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
18th Feb 2023 9:36am |
Customer has said it was supplied by a reputable retailer. Clearly it isn't |
18th Feb 2023 9:47am |
Could it be the 2 stroke oil mixture? visiting from www.rrsport.co.uk |
18th Feb 2023 11:19am |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1149 |
Is the engine now? overfinch modified |
18th Feb 2023 12:09pm |
Not sure if serious or sarcastic This was, apparently, white diesel, delivered directly from a nationwide fuel supplier. Clearly something has gone wrong someplace |
18th Feb 2023 12:52pm |
Sorry I was being serious thinking perhaps someone's been experimenting. visiting from www.rrsport.co.uk |
18th Feb 2023 4:36pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 746 |
I thought the same - someone trying a Kerosene/2 stroke mix? |
18th Feb 2023 9:09pm |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 490 |
That is nuts, someone spending tens of thousands on a modern motor and scrimping on fuel.
18th Feb 2023 9:24pm |
