Home > Maintenance & Mods (L405) > Electric Tow Bar Won't Retract
rdp1988
Hi all
I have just purchased a 2013 Vogue SE. The tow bar is currently deployed and I would like to retract it as I'll never need to use the tow bar. The manual in the vehicle doesn't mention anything about the tow bar but I found a guide on how to deploy/retract.
This is not working. When I select the on/off button - it goes red and stays red. The deploy/stow button flashes green (whilst the on/off button is solid red) and there is a beeping noise for a few seconds. The to bar doesn't move at all.
It is worth noting that before purchasing the vehicle, a new battery was supplied and fitted (Napa battery AGM START STOP) - not sure if this will have anything to do with the tow bar system.
Appreciate any advice, I have read a guide on how to reset the system which I have tried and made no difference. Although I have found two different guides online and not sure which one is correct.
Post #656521 13th Feb 2023 6:48pm
Hi & welcome to the forum.
My fear is always the opposite, I'll need the tower & it won't deploy - but fortunately that hasn't happened.....yet.
There are a few clues on this thread which may help (or may not)
I also recall something about gear cogs which can degrade.
The deployable tow bar is not in the main manual, there was a supplementary few pages that should be with the handbook, but could easily become separated. However, it sounds like you have it figured out - press one button, then the other - mine then starts beeping and deploys or retracts. Needs to be engine off I think.
There's always this 'service action' which may be worth checking with a main dealer ?
Post #656522 13th Feb 2023 7:11pm
supershuttle
The one thing I did find was that if you hold the deploy or store button apparently the battery supplies a little bit of extra juice. I keep mine deployed now I have got it out because I use it fairly regularly (bike rack). There is a reset procedure in my manual I just followed that. Geoff
Post #656523 13th Feb 2023 7:16pm
rdp1988
Thanks for the responses. It turned out the motor was completed dead. Ended up having the tow bar removed
Post #666667 15th Jun 2023 11:58am
zenman63
England 2016 Range Rover Autobiography SDV8 Indus Silver
I will buy that tow bar if it’s for sale?
Post #666895 18th Jun 2023 8:24am
