Home > Technical (L322) > How Do You Run Engine at 500 RPM
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
Workshop Manual reads:
The following conditions must be met to allow the diesel particulate filter pressure sensor offset value to be learnt and stored: Using the manufacturer approved diagnostic system, clear DTCs from engine control module, then monitor the datalogger signal 'sump oil temperature - measured' ensuring a minimum of 50 degrees C is achieved. Start engine, run above 500rpm for 2 minutes, then a further 30 seconds at idle. Ensure the engine cooling fan is not running. Set vehicle in park and set ignition status to off. Wait 30 seconds for the engine control module to power down, learn and store diesel particulate filter pressure sensor offset value. This process must be carried out six times, to allow a large negative offset value to adapt back to 0 Hpa.
I will be installing a new DPF Pressure Sensor next week. My question is how do you run the engine at 500RMP when Idle is over 600????
Is this a typo? does anyone know the correct RPM to run the process at?
Flummoxed....
Any advice appreciated...
John
 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #657706 25th Feb 2023 8:33am
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
It says 'run above 500RPM' then at idle, so if idle is 600, I'd just rev it up to say 1000 as that's above 500 and idle. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #657707 25th Feb 2023 8:39am
4434Morrison
Many thanks, will give that a go....
John 2012 4.4 TDV8 Vogue SE Current
Post #657710 25th Feb 2023 9:03am
Phoenix
It should read 'above 2500rpm'. The test and calibration will fail if it isn't. If you were doing it through SDD then the on-screen text would read 'above 2500rpm'.
Post #657798 25th Feb 2023 6:58pm
4434Morrison
Many thanks Phoenix,
Calibrated the existing Sensor based upon the previous advice, which failed resulting in a further Pressure Sensor being ordered last week.
I will be fitting a new Pressure Sensor purchased from Duckworths next week and will then calibrate the sensor as per the workshop manual but at 2500 RPM.
Hopefully this will resolve my issues.
Post #658421 4th Mar 2023 10:25am
Phoenix
If you have access to an air compressor, blow down the pipes before fitting the new sensor to ensure they're clear and disperse any condensation in them.
Post #658448 4th Mar 2023 2:39pm
4434Morrison
Very helpful, makes sense. Will order a small compressor. off eBay and give the pipes a blow through.
Post #658452 4th Mar 2023 3:38pm
