![]() | Home > Technical (L322) > How Do You Run Engine at 500 RPM |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
It says 'run above 500RPM' then at idle, so if idle is 600, I'd just rev it up to say 1000 as that's above 500 and idle. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
Many thanks, will give that a go....
It should read 'above 2500rpm'. The test and calibration will fail if it isn't. If you were doing it through SDD then the on-screen text would read 'above 2500rpm'. |
Many thanks Phoenix,
If you have access to an air compressor, blow down the pipes before fitting the new sensor to ensure they're clear and disperse any condensation in them. |
