![]() | Home > Technical (L405) > Headlight adjustment foe Europe |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Hi Geoff,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35507 ![]() ![]() |
no adjustment needed
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 183 ![]() ![]() ![]() |
Ah ha, found it and yes, I have adaptive. Thanks guysđź‘Ť |
I defo have a setting in the menu but might it be for full beam ..?? Ash
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 ![]() ![]() ![]() |
I am not 100% sure, but I think the menu setting is for the auto high beam.....so it knows which way to "look" for oncoming lights. |
That would make sense Philip.
But my adaptive lights dip when the street scene gets brighter. By that I mean mainly street lights and not necessarily oncoming traffic. It's a puzzle. Edit: Just found this in the manual The hand of traffic can also be selected within the instrument panel menu. As default, this is set to be opposite the hand of drive. If the vehicle is Left Hand Drive (LHD), the hand of traffic is Right Hand Drive (RHD). I had to read that a couple of times! |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1156 ![]() ![]() ![]() |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3198 ![]() ![]() |
I know this is the wrong section, but does anyone know how to adjust L322 lights for Europe? |
lever in the headlight enclosure..
I would argue that the info is incorrect, as the 405 has a kick up to the left for use on UK roads. This surely has to be illegal for use in euroland no? |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1245 ![]() ![]() |
Not always Stan…. On one of mine as you said, but on the next one they had “improved” the system. A little lever in the same place, but on a spring. So it always returns to the same position. Had I pressed it far enough? had I not? NO WAY of telling which way which headlight was pointing… other than shining them on a blank wall at night. Upset a lot of frenchies when I got it wrong to start with. Anyway all changed again & now from menus. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc He who dies with the most toys wins... |
Is that sorted by the "hand of traffic" option though? |
