Home > Technical (L405) > Headlight adjustment foe Europe
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
My 2015 autobiography.
Is this done from a menu or manually under the bonnet?
TIA
Geoff
Post #655245 31st Jan 2023 12:15pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi Geoff,
My 2016 has a settiing in the dash menu - I believe it can be set for LH or RH drive
HTH Ash
2016 SDV8 AB
Post #655247 31st Jan 2023 12:34pm
no adjustment needed
[unless you have adaptive lighting]
Post #655249 31st Jan 2023 12:59pm
RRV8SC
comports wrote:
Hi Geoff,
HTH
Ah ha, found it and yes, I have adaptive.
Thanks guysđź‘Ť
Post #655250 31st Jan 2023 1:04pm
comports
I defo have a setting in the menu but might it be for full beam ..?? Ash
2016 SDV8 AB
Post #655256 31st Jan 2023 3:04pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I am not 100% sure, but I think the menu setting is for the auto high beam.....so it knows which way to "look" for oncoming lights.
Post #655272 31st Jan 2023 5:24pm
comports
That would make sense Philip.
Thx Ash
2016 SDV8 AB
Post #655274 31st Jan 2023 5:32pm
RRV8SC
But my adaptive lights dip when the street scene gets brighter. By that I mean mainly street lights and not necessarily oncoming traffic.
It's a puzzle.
Edit: Just found this in the manual
The hand of traffic can also be selected within the instrument panel menu. As default, this is set to be opposite the hand of drive. If the vehicle is Left Hand Drive (LHD), the hand of traffic is Right Hand Drive (RHD).
I had to read that a couple of times!
Post #655276 31st Jan 2023 5:36pm
caymanblack
Laughing me too. overfinch modified
Post #655280 31st Jan 2023 6:41pm
Dolphinboy
I know this is the wrong section, but does anyone know how to adjust L322 lights for Europe?
Post #655285 31st Jan 2023 7:57pm
lever in the headlight enclosure..
up for UK and down for euroland.. ... - .- -.
Post #655290 31st Jan 2023 8:49pm
I would argue that the info is incorrect, as the 405 has a kick up to the left for use on UK roads. This surely has to be illegal for use in euroland no?
Post #655312 1st Feb 2023 12:14am
Bill
Not always Stan…. On one of mine as you said, but on the next one they had “improved” the system. A little lever in the same place, but on a spring. So it always returns to the same position. Had I pressed it far enough? had I not? NO WAY of telling which way which headlight was pointing… other than shining them on a blank wall at night. Upset a lot of frenchies when I got it wrong to start with.
Anyway all changed again & now from menus. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #655381 1st Feb 2023 5:58pm
RRV8SC
Is that sorted by the "hand of traffic" option though?
Post #655388 1st Feb 2023 6:09pm
