Home > Technical (L405) > Drone at speed
Silverstone
United Kingdom 2016 Range Rover Vogue SE SDV8 Loire Blue
Drone at speed
I’ve had my 2016 SD V8 L405 about six weeks. It’s fine 54000 miles. Driving to Somerset and back (about 100 miles each way) I’ve noticed a slight drone at 50 mph+. This is only under load and disappears when decelerating. It’s very quiet and only just noticed it. The tyres are recently balanced and everything else is in order. It does this in straight line and doesn’t vary on left/right curves in the road. The car is running Pirelli scorpions on 20 inch rims if that helps. Could this be something simple or common? (Hope nothing serious 🤞) "There is no replacement for displacement" - W O Bentley
Post #699655 6th Sep 2024 11:28pm
evotime
Likely a diff starting to become noisy. might stay like that for years. Had very similar on my Sprinter. Started with a very slight drone under power (could hear something in the background) but quiet when power was removed. It got real noisy in around 600 miles to the point I limped home, even then, quiet with no load but crazy loud when I touched the throttle.
Start with changing the diff oils. Pretty cheap and doable DIY for little money. You might catch it before it gets worse X5 40d
Post #700801 24th Sep 2024 6:41pm
Dolphinboy
check exterior trims - could be A pillar or front scuttle? or heat shield under car?
Post #700834 25th Sep 2024 9:47am
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
What are the revs at this point? Mine does it at circa 1300/1500 revs (under load only) and is the exhaust heat shield Thumbs Up 2013 L405 Autobiography Baltic Blue
2007 L322 Vogue Buckingham Blue
Post #700837 25th Sep 2024 12:10pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Used to get this all the time , until her indoors stopped talking Rolling with laughter Mr. Green Rolling with laughter
Here all week , get your bookings in.
Post #700842 25th Sep 2024 1:21pm
