Home > Maintenance & Mods (L322) > air hose
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
air hose
hi
i have an problem with my rear near side dropping after a few hours ,have replaced the air bag but still the same so thin king may be the air hose its self so looking at replacing it but want to buy it by the meter........can anyone recommend a supplier?
thanks will
Post #654865 27th Jan 2023 12:22pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Did you replace the Voss fitting at the same time as the bag if the bag didn't come with a new one? They're not unknown to leak after removal and replacement.
Post #654878 27th Jan 2023 2:13pm
will308f
yea air bag came will one fitted ,so that's why i was thinking it could be the air pipe chaffed over the years ? maybe ??
Post #654885 27th Jan 2023 3:34pm
Danb_220_2019
It's certainly possible. Valve block is another possibility, and there are refurb kits for them available, I believe.
Post #654886 27th Jan 2023 3:36pm
will308f
I've already done the valve block and replaced the rubber seals on the voss seals on the valve block ....not saying that i haven't missed something in the valve block hence why i was thinking it could be the air pipes but could be the voss seal on the airbag
Post #654887 27th Jan 2023 3:41pm
