![]() | Home > Maintenance & Mods (L322) > air hose |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
Did you replace the Voss fitting at the same time as the bag if the bag didn't come with a new one? They're not unknown to leak after removal and replacement. |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 456 ![]() ![]() ![]() |
yea air bag came will one fitted ,so that's why i was thinking it could be the air pipe chaffed over the years ? maybe ?? |
It's certainly possible. Valve block is another possibility, and there are refurb kits for them available, I believe. |
I've already done the valve block and replaced the rubber seals on the voss seals on the valve block ....not saying that i haven't missed something in the valve block hence why i was thinking it could be the air pipes but could be the voss seal on the airbag |
