Home > Technical (L405) > Multiple warning lights after new alternator and battery
James Brown RR
Just before Xmas after scrapping ice off the windows I set off and got multiple warning lights on the dash of my L405 SDV8. It went into limp mode and I drove it home. My mechanic came round and diagnosed an Alternator fault. Car got left till Jan as he couldn't fit it in and when the tow truck came after Xmas the battery was completely dead.
My mechanic replaced the battery, alternator and belt and cleared down the multiple faults. He was taking it for a test drive and all was working well and then all the warning lights came back on and the handbrake started playing up.
Anyone experienced this? Any ideas? The battery was completely dead for a week or two - is there a way of resetting - my guy is scratching his head - he is a specialist LR guy and normally very good.
Thanks in advance for any ideas.
KR,
James SDV8 Vogue SE
SDV6 RR Sport
TDV6 Vogue SE
3.0D Velar HSE Dynamic
SDV8 Autobiography
Post #654860 27th Jan 2023 11:53am
AnotherMutley
Is it related to this;
https://www.fullfatrr.com/forum/topic65812.html
Loose earth?
Post #654868 27th Jan 2023 1:40pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Yes mine has been diagnosed as faulty earth connections in wheel arch
Post #654888 27th Jan 2023 4:41pm
James Brown RR
Thanks very much for the responses.
My guy has tested all the earths and says not - any other ideas?
He is saying that because the battery was dead for a while that he thinks the system needs to be reset but needs a more in depth diagnostic tool than the one he has to check out further. SDV8 Vogue SE
SDV6 RR Sport
TDV6 Vogue SE
SDV8 Autobiography
Post #654960 28th Jan 2023 2:17pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Dont you need to tell the car its had a new battery?
Post #654963 28th Jan 2023 3:23pm
James Brown RR
Yes done that SDV8 Vogue SE
SDV6 RR Sport
TDV6 Vogue SE
SDV8 Autobiography
Post #654964 28th Jan 2023 3:24pm
DrF
The other issue that MD thought could be on mine was a speed sensor which can also throw faults like yours, or a fault in abs unit
Post #654978 28th Jan 2023 5:04pm
