Home > Technical (L405) > Restricted Performance and Weird Noise and won't turn oif
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hey Folks
Got a weird one, driving home and get restricted performance no errors on the IID at all, looked at loads of posts suggesting turbo hose issues but can not find any.
Its a 2013 4.4 SDV8.
If you listen to the sound in this video when you rev and come off there's a weird noise, like the eggier is suffocating, any ideas welcome, my first diesel FF after 3 petrols.
https://youtube.com/shorts/lHPpMhLOxbg
Post #654930 27th Jan 2023 10:00pm
knwatkins
That's turbo flutter. Mine does it very occassionally. It's fairly common as there is no blow off valve and generally nothing to worry about.
In fact, I'm not sure but it may coincide with DPF regen.
Not sure if that is the cause of your restricted performance issue. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #654966 28th Jan 2023 3:46pm
