Home > Technical (L405) > Deployable side steps.
caymanblack
So today my driver's side step has been strange. Open the door and out it comes, close the door, a little judder then remains out. I shut the door then give it a little help and it closes. Question Question It is all well lubricated. overfinch modified
Post #654794 26th Jan 2023 4:26pm
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
Mine’s doing exactly the same. Passenger side working fine 2017 (67) Vogue SE Corinthian Grey
Post #654797 26th Jan 2023 4:47pm
cass
No matter how well lubricated it is I'd still bet money on it being a lack of PROPER lubrication.
A squirt of spray of anything does next to nowt, I've found on L322 and L405 the only way was to remove the bracket/hinges, dismantle as much as possible then soak them and work them manually until they free up.
They are a pretty hopeless design for a country that puts salt on the roads, there isn't a way to get any lube into the joints.
Post #654798 26th Jan 2023 4:59pm
TJH1985
Cass is spot on, there are also a couple of joints that are higher up and easy to miss. I found that ACF50 worked well on ours, I used white lithium once I get them working well and that seems to have kept the water and crud out. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #654800 26th Jan 2023 5:03pm
Abacus405
Thanks for the replies, is this something I can do without ramps/axle stands? I.e. on off road setting? 2017 (67) Vogue SE Corinthian Grey
Post #654802 26th Jan 2023 5:15pm
TJH1985
I’ve always done mine in off road height without issue. It does take more than a quick spray though, so take a warm cup of tea with you!
On mine it was the rear hinge, and from memory there were 4 axles to lubricate on each side. With some manual assistance to work them in and out a few times that got them working and I then did the fronts for good measure.
Mine only needed a very light pull to help them come out. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #654805 26th Jan 2023 5:30pm
Abacus405
That’s great advice thanks. Can you “work them in and out” without disconnecting the actual step? I’ve tried pushing and pulling on the step without any movement. 2017 (67) Vogue SE Corinthian Grey
Post #654806 26th Jan 2023 5:46pm
TJH1985
I just worked them in and out on the motor with some gentle assistance by locking / unlocking the car - I.e out lubricate everything, back in lubricate, leave it to work 10-15m while back inside and then back out and repeat etc I kept doing it until it could reliably do it itself then gave it a final soak over night followed by more of the same in the morning and then some lithium spay grease.
That’s just my experience, mileage may vary! Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #654810 26th Jan 2023 6:18pm
rstoughy
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Just to add to this.
What I did was flush the hinges out with WD40 while doing the open / close doors thing to operate the steps (the stuff running out was pretty brown / rust coloured fluid)
When all done I used a Wurth spray lubricant with a straw and sprayed that back in while continuing to work the steps in and out.
I now make a point of every other month I just get under there and give them a spray.
I've often thought of trying to make some sort of rubber shield to protect the hinges from tyre spray but never gotten round to that yet.
Post #656712 15th Feb 2023 10:04am
Gremlin500
TJH1985 wrote:
Cass is spot on, there are also a couple of joints that are higher up and easy to miss. I found that ACF50 worked well on ours.
#2:
I use ACF50 on ours a couple of times a year. The passenger side sems to stick the most as used less.
ACF50 is great on all sorts of stuff left outdoors like padlocks etc, and is even OK on electrical parts.
All the biker guys use it for Winter protecton. Not cheap, but effective. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #656717 15th Feb 2023 11:03am
