![]() | Home > Technical (L405) > Deployable side steps. |
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 109 ![]() ![]() ![]() |
Mine’s doing exactly the same. Passenger side working fine 2017 (67) Vogue SE Corinthian Grey |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 761 ![]() ![]() |
No matter how well lubricated it is I'd still bet money on it being a lack of PROPER lubrication.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Cass is spot on, there are also a couple of joints that are higher up and easy to miss. I found that ACF50 worked well on ours, I used white lithium once I get them working well and that seems to have kept the water and crud out. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Thanks for the replies, is this something I can do without ramps/axle stands? I.e. on off road setting? 2017 (67) Vogue SE Corinthian Grey |
I’ve always done mine in off road height without issue. It does take more than a quick spray though, so take a warm cup of tea with you!
That’s great advice thanks. Can you “work them in and out” without disconnecting the actual step? I’ve tried pushing and pulling on the step without any movement. 2017 (67) Vogue SE Corinthian Grey |
I just worked them in and out on the motor with some gentle assistance by locking / unlocking the car - I.e out lubricate everything, back in lubricate, leave it to work 10-15m while back inside and then back out and repeat etc I kept doing it until it could reliably do it itself then gave it a final soak over night followed by more of the same in the morning and then some lithium spay grease.
rstoughy Member Since: 17 Dec 2022 Location: Stonehaven Posts: 24 ![]() ![]() ![]() |
Just to add to this.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1691 ![]() ![]() ![]() |
#2: I use ACF50 on ours a couple of times a year. The passenger side sems to stick the most as used less. ACF50 is great on all sorts of stuff left outdoors like padlocks etc, and is even OK on electrical parts. All the biker guys use it for Winter protecton. Not cheap, but effective. ![]() |
