Home > Technical (L405) > L405 5.0 Supercharged Major Problems - Need some help please
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
Result!! And a relatively cheap result too. First time FFRR owner
Post #654892 27th Jan 2023 4:52pm
AnotherMutley
@DrF, did the bulb blow or was everything ok once the earthing points had been tightened?
Post #654895 27th Jan 2023 5:30pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
The original headlamp seems to operate perfect.
Not a simple fix, the earth points need changing as they have completely failed, not such an easy job but in reality a result as I had thought the worse Thumbs Up
Post #654927 27th Jan 2023 9:34pm
