![]() | Home > General > Considering a 4.4TDV8 |
850miles on a single tank? 2012 TDV8 Vogue (L322) |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
no two different days with a top up on the second day etc don't recall the tank calculations.. |
850 miles would be just possible on a single tank if that was your actual mpg. 2012 TDV8 Vogue (L322) |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3879 ![]() ![]() ![]() |
Think 25 mpg knocking about and you won't be far wrong |
I'm currently getting just over 30mpg on average and I do mostly M-Way driving at very sensible speeds. This is calculated from fill vs trip miles. It's doing a bit less than usual at present due to the cold weather ( always a factor with any cars MPG) and also a leaky thermostat so hope to see this improve bit when it's fixed next week. I did squeeze 750 miles from a tank once in the warmer months when I was just M-Way cruising and the low fuel warning had only just lit up - do the maths if you want but this is very good but not quite 40mpg..... 2012 TDV8 Vogue (L322) |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 123 ![]() ![]() ![]() |
Over the 9,795 miles I’ve had the car doing a right mix of journeys, my actual calculations show an average of 25.5. My last tank was 26.3, much improved from the 24.4 of the previous tank which I put down to realising the tyres were under inflated. Since getting them back to normal pressures the mpg has improved. |
