![]() | Home > Technical (L322) > Over-eager kickdown when on cruise control only (2010 TDV8) |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
I have the same gearbox as you and yes, this does happen (very annoying). I usually end up sticking box into manual. Must remember to put back into auto when slowing down, coming off at a junction, as can get caught in a lower gear inadvertently. Previous cars:
JamesDarby Member Since: 29 Sep 2021 Location: Rugby Posts: 24 ![]() ![]() ![]() |
I have the 4.4 TDv8 and it does the same thing, it will drop down a couple of gears sometimes just to pick up say 15mph which it could easily do without changing gear at all. 2011 Range Rover Autobiography TDV8 Buckingham Blue |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2578 ![]() ![]() ![]() |
With my 4.4 if I don't want to use manual mode to prevent the downshifts but I think that it might downshift on a rise then I'll press the upshift paddle for temporary command-shift mode which will be maintained until the gearbox doesn't feel the need to downshift by reverting to full auto mode.
ttrw2 Member Since: 27 Dec 2015 Location: Oxfordshire Posts: 51 ![]() |
Thanks. This is the 3.6TDV8 with the 6 speed box.
Yes I find myself doing the same - knocking the stick across to manual mode and leaving it in 6th gear. It accelerates/climbs hills perfectly well at motorway speeds without the need to drop a gear IMO. |
Had the ZF6sp on my old audi A6 Quattro and it did the same but it never particularly bothered me. My ZF8 holds gears too long on hills IMO so I often use the paddles to change up - not sure if the gearbox is sensing extra load or it's getting an input from the body control system that it's on a hill? It holds gears under acceleration on the flat pretty well without dropping down. Worth on either box checking you have the latest gearbox software update. Also if you have a bigger tyre aspect ratio than stock this will change gear change behaviour. 2012 TDV8 Vogue (L322) |
CJ_44 Member Since: 12 Aug 2022 Location: Hampshire Posts: 5 ![]() ![]() |
I was toying with also asking this. Wasn’t sure if this was normal. Good to know, albeit unnecessarily eager!
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 191 ![]() ![]() ![]() |
Having driven today towing a trailer from foggy Herefordshire to sunny Reading and back I put the instant fuel on the screen (very scary by the way) and tried leaving it full auto and knocking it in 6th and leave it there. According to the car there is very little difference in fuel economy between auto and leaving in top, quite counter intuitive I know but I will leave it in auto now and let it get on with it, driving without a trailer will be easier on the engine and might well work, but I will leave it to do it's thing.
Thanks all, looks like this over-eagerness to kickdown when in cruise control is a characteristic of the way they've calibrated the car then.
