Home > Technical (L322) > O2 sensor codes
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
O2 sensor codes
In further preparation for the old girl's annual Healthcare, I pulled the following codes with the GAP IID:
0x41A Lambda control adaption exceeds lower limit bank 1
0x40C O2 sensor circuit bank 1 downstream sensor
Car is running sweet, no warnings, no check engine light, no hiccups, good (as normal) mileage.
Wouldn't have known had I not read the codes.
All 4 O2 sensors were replaced 3 years ago ~80K Km
Should I just add a new sensor to the work list or is there anything else I should be looking at?
Thanks
Post #654333 22nd Jan 2023 11:02am
