Home > Technical (L322) > TDV8 4.4 fuel tank capacity?
AMV
2011 Range Rover Vogue TDV8 Santorini Black
Well, Gents, thanks for the input. I definetely trust more you and the manual then the guys from the sales dept Laughing
It also looks like the fuel gauge is not that accurate and that is not so good Rolling Eyes Santorini Black RR Vogue 4.4 TDV8
Post #71313 5th Jul 2011 7:04pm
p-trax
Japan 2011 Range Rover Vogue 4.4 V8 Santorini Black
I stuck 95 litres in yesterday, and it wasn't exactly running on fumes when I stopped off at the garage! Gerry
____________________________________________
Arrived>Santorini/Jet FFRR MY11 TDV8
Gone>Stornaway/Ebony MY09 RRS HST TDV8
Gone>Java black/Ebony MY07 RRS HSE TDV6
Post #71337 5th Jul 2011 8:16pm
JustinP
Are all FFRR's fitted with the same size fuel tank?
I'm sure I read the capacity of mine was 115 litres, or did I dream that?
Post #71341 5th Jul 2011 8:25pm
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Diesels self-prime these days, no need to worry about that
And the 'sludge in the tank'... well you'd hope the fuel filter would help with that issue 2008/58 FFRR 3.6 TDV8 Vogue
Post #71348 5th Jul 2011 9:11pm
That's excellent, and about time!
When did they start self priming? After the TD6 I take it? Laughing
Post #71367 6th Jul 2011 8:29am
jonminns
I had a van made in 2002 which self-primed! The TD6 engine was reasonably old when it found its way into the Range Rover though 2008/58 FFRR 3.6 TDV8 Vogue
Post #71379 6th Jul 2011 11:39am
Avi
2006 Range Rover Vogue Td6 Alveston Red
Mikeyjd wrote:
verydisco wrote:
RRUK wrote:
I think I am going to buy a jerry can for Diesel and have it in the boot and see just how far beyond "Range = 0 miles" I can get, put a gallon in and then go fill up to see how many litres go in.
Cat'ed & turboed diesel engine hate this kind of treatment ! Do not do it, your Rangie will thank you
Plus you will suck in all the crap that collects at the bottom of your tank.
Also, make sure you never go off road or over any bumps, as this may shake the crap up from the bottom of the tank.
Post #71384 6th Jul 2011 12:22pm
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
Not sure all diesels self-prime. At least the TDV6 in the D3 doesn't. Before you take that trip with the Jerrycans make sure you know where the air bleed is and what the priming sequence is.
On the D3 you have to turn the key to II about 10 times then eject the air from the system thru the bleed valve located on top rear of the engine.
How do I know this? Cos I ran out of diesel on my own driveway with 64km range showing on the display.
My FFR is supposed to have a 105 liter tank but I have never managed to get more than 88l in.
I also want to do the jerrycan trick one day when I have time, cos I suspect the gauge is lying
Post #71416 6th Jul 2011 4:43pm
