![]() | Home > Technical (L405) > Coolant / Expansion Tank Level |
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 44 ![]() ![]() ![]() |
My oil cooler gaskets needed replaced, once done I also noticed the same as you. Topped up level ( to oval hole inside bottle) and noticed that level would slightly drop when checked. It would not drop much just a cup full to fill back to mark, and this was after weeks of job been done. Pressured tested system- No drop in pressure or leaks. Stripped down again to check -all ok. In my opinion is that the system is large and ( if fitted) goes though fuel burning heater etc. so lots of places air can be trapped.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 464 ![]() ![]() ![]() |
Mine always drops to just below the oval cut so you cant see it without removing the trim but seems to settle there and not lose any more. |
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 ![]() ![]() ![]() |
Mine took over 300 miles to settle down to around the top of oval after a new water pump fitted. Thanks for the reminder that I haven't looked for a while so just checked and after another 330 miles it's towards the bottom of the oval (but still in the oval). A miniscule difference that I'm quite happy to attribute to ambient temperature. Chris
Bigfella70 Member Since: 22 Jan 2016 Location: Yorkshire Posts: 106 ![]() ![]() ![]() |
Thanks gents, that ties in with how mine has settled in terms of level. Much appreciated |
