Home > Technical (L405) > Coolant / Expansion Tank Level
Bigfella70
United Kingdom 2016 Range Rover Vogue SE SDV8 Santorini Black
Afternoon all,
Silly question / query. Had the oil cooler replaced recently on my MY2016 4.4 SDV8. Subsequently keeping an eye on coolant level in the expansion tank as air locks have bled off.
I’ve found when topped up that it finds its level just below the oval cut out / hole that’s visible when looking inside the tank with cap removed. When I’ve topped up just lapping over this level it seems to settle back to just below.
Looking at the side of the tank with the engine bay trim removed the exact level not entirely clear but can see approx at max when cold.
So my question is could others advise where their coolant level tends to level out in relation to oval cut out as a reference point?
Just wanting to ensure I’m not suffering slow coolant loss etc ……. Current
2016 MY L405 SDV8
2018 VW Golf GT EVO
2001 BMW Z3 2.2
Previous
2002 L322 TD6
2004 Mercedes R230 SL350
1994 993 Carrera
Range Rover P38 x3
Range Rover 3.9 EFI
Post #653362 12th Jan 2023 12:48pm
M11buc
United Kingdom 2019 Range Rover Autobiography SDV8 Santorini Black
My oil cooler gaskets needed replaced, once done I also noticed the same as you. Topped up level ( to oval hole inside bottle) and noticed that level would slightly drop when checked. It would not drop much just a cup full to fill back to mark, and this was after weeks of job been done. Pressured tested system- No drop in pressure or leaks. Stripped down again to check -all ok. In my opinion is that the system is large and ( if fitted) goes though fuel burning heater etc. so lots of places air can be trapped.
I have just topped each time low and monitoring it.
Post #653416 13th Jan 2023 6:22am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Mine always drops to just below the oval cut so you cant see it without removing the trim but seems to settle there and not lose any more.
Post #653418 13th Jan 2023 8:23am
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
Mine took over 300 miles to settle down to around the top of oval after a new water pump fitted. Thanks for the reminder that I haven't looked for a while so just checked and after another 330 miles it's towards the bottom of the oval (but still in the oval). A miniscule difference that I'm quite happy to attribute to ambient temperature. Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #653427 13th Jan 2023 10:49am
Bigfella70
Thanks gents, that ties in with how mine has settled in terms of level. Much appreciated Thumbs Up Current
2016 MY L405 SDV8
2018 VW Golf GT EVO
2001 BMW Z3 2.2
Previous
2002 L322 TD6
1994 993 Carrera
Range Rover P38 x3
Range Rover 3.9 EFI
Post #653485 13th Jan 2023 5:20pm
