Home > Maintenance & Mods (L322) > Deployable Side Steps Dead |
Essentially, the AHU plug & socket that picks up the CAN & illumination needs to be disconnected from the AHU and the vehicle harness - so the only connection to the vehicle is the heavy power - obviously this means the black plug needs to be connected to the sidestep control module, the motors & the switch can be left connected.
9th Mar 2023 9:01pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
It’s a shame you’re not closer to Scotland as that curse would see me booking this thing in with you
9th Mar 2023 11:14pm |
Just a thought - can you see the door status in the PATS module? if so is it plausible?
10th Mar 2023 7:22am |
Which one is the PATS module? I’ll have a look with the IID at Live Values later on and see if I can see them but I’m not sure which the PATS module is.
10th Mar 2023 10:34am |
Right, new switch fitted and surprise surprise, it’s still dead.
10th Mar 2023 1:52pm |
Right, well the park brake could have a bearing on it, why all of a sudden, I have no clue.. I'm fairly certain that the park brake doesn't have to be applied, only the transmission needs to be in park. That said, with (presumably) a DTC set, it may be an unintended consequence. Can you clear the DTC? Even if it comes back later, if it stays off long enough for testing the steps, that should prove if it has a bearing or not. Also, it it possible to try initializing the steps with the CAN disconnected from the harness end but still connected to the AHU (so it has someone to talk to) It might do nothing if its looking for ignition and door status though.
10th Mar 2023 3:40pm |
The car is back together at the moment as I need it to use the trailer tomorrow.
10th Mar 2023 6:29pm |
With that DTC, if it was in work we'd be looking to resolve that before going any further, the reason being it's essentially saying that packets sent are unreliable or missing, that can degrade the whole dataset. I don't know why it hasn't had any effect prior, unless there was a different, lower order DTC that was only local to the park brake.
10th Mar 2023 7:32pm |
Unfortunately, fixing the park brake issue means dropping the rear subframe so it’s going to have to wait for a bit as I just don’t have time at the moment. It’d also be nice for it to be a bit warmer before I start doing that!
10th Mar 2023 9:52pm |
Looking back over your parkbrake issues, TBH I'd just make an overlay harness and splice that in - no need to lower the rear subframe and would probably be only a couple of hours work. If you want a few metres of suitable twisted pairs, I'm sure I could find some. |
10th Mar 2023 10:03pm |
I’ve come to the conclusion that there’s an issue with the wiring above the subframe going into the handbrake module. I can just get my hand up to unplug the connector but I can’t get enough slack on the loom to get a proper look at it unfortunately. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
10th Mar 2023 10:21pm |
I finally managed to get time to sort the parking brake issue today. When inspecting the wiring loom there was a green blob on it. It hadn’t chaffed on anything which was my initial concern.
21st May 2023 3:21pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
David, I reckon you could fall into a bucket of tits and come out sucking your thumb pal! |
21st May 2023 5:02pm |
21st May 2023 6:34pm |
