![]() | Home > Maintenance & Mods (L322) > Deployable Side Steps Dead |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3146 ![]() ![]() ![]() |
Thanks Phoenix.
Update.
Thinking logically, the three unknown (red, orange & blue) function wires should be a +12V permanent supply for the electronics - possibly the orange, an illumination +ve for the switch backlighting level, possibly red, and a switched +ve to signal power up/power down, I'm guessing blue, purely on the basis that it will be coming from the infotainment relay output. If I'm right, then (ignoring the illumination input which can be checked for quite easily) for anything to work, the other two should be at battery voltage, one permanently - possibly/probably fed from fuse 49 of the CJB with the switched supply fed from fuse 10 or 11 in the rear junction box. All of the above is clearly pure guesswork, based upon nothing other than what's available at the AHU and how I think it should work.
Thanks Phoenix |
I've just re-read the earlier posts - your comment about being above the heater vent may 'have legs', not in terms of damaging the control module but in terms of relaxing the pin grip in the connector housing...
Been back out and have a look at this again this evening. Here’s what I’ve managed to trace tonight.
That helps a lot - there is a Red/Green on pin 11 that is a battery supply, same connector as CAN, this should be live all the time, probably the electronics supply that is missing. I'll try & track down the White, Grey/Red & Red/Blue
That’s a big help, thank you.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
David, may I start by stating the obvious... Did you check all the fuses in the car?
The fuses will most likely be OK - that's why I asked if the infotainment system was operating as expected, other than the functional power, everything else is piggy-backed from the AHU. The step control module has also had it's power reset at least twice. |
I have indeed.
Hence me asking about fuses David... Even the diddy 5amp fuses can interfere with the steps getting their signals... |
I flicked through the handbook and looked for anything that might affect them but didn’t spend a lot of time on them as everything else appeared to work and there was no separate fuse listed for the steps.
It's worth metering every fuse David... Doesnt take very much time...
