How often does the air suspension compressor turn on? | |
I have experience with custom air suspension before, so I'm asking this question based on LR L322 operation.
MY08 HSE (USA)
My air compressor turns on on every cold start and runs for some time (at least 2 min), stops, then runs again - presumably because it's overheating and needs to cool down. Is the system from the compressor to the air tank/reservoir and valves supposed to hold air at all times, or is it supposed to release air somewhere after some time of inoperation as part of some LR system procedure? O do not have any fault codes.
All four of my air bags hold air on all heights overnight (off-road, standard, access). There are absolutely no leaks with measurement being exactly the same from ground to fender.
I am going to spray some soapy water at fittings throughout and wanted to know where common trouble areas are. However, I also wanted to know first if I am approaching this for the wrong reason -of whether depressurizing the air tank is normal operation or not. In the mean time, I've pulled fuse F13 5A for air suspension in the rear fuse box to prevent possible compressor overuse with the expected ding, fault message normal height only, and a disabled terrain response + height adjust switch (no illumination). Thanks in advance for responding.
