Home > Technical (L322) > Top coolant hose connection |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 400 |
i ended up cutting the quick fit pipe out and reusing the old pipe. it know it's not OEM but thinking about it seems to make more sense.
30th Dec 2022 10:42pm |
blackpool Member Since: 14 Aug 2022 Location: Blackpool Posts: 24 |
If you mean the (four way) connector at the other end of that thin hose in your photo I saw an aluminium connector on a forum in the states. I don't think they are available off the shelf. I concluded the person in question bought a large bore straight (or T) piece aluminium hose coupling (they can be googled - I think they are available in the UK) and then drilled and tapped (or welded) the two smaller side connectors.
31st Dec 2022 1:10am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
i have got rid of that hose completely and fitted a rubber coolant hose, so i no longer have that speed fit connection!! 2012 Vogue 4.4 TDV8 - Current
31st Dec 2022 9:35am |
That's what previous mechanic did and now an inclined to stick with it Its actually a sport
31st Dec 2022 10:06am |
am struggling to find how to bleed this sucker.
31st Dec 2022 11:29am |
Went with best judgement, whacked open bleed screw and started filling with the heater on full temp and power till it couldnt take anymore.
31st Dec 2022 12:42pm |
I used a vacuum filler but from memory the wiki workshop manual has bleeding instructions |
31st Dec 2022 2:25pm |
Yeah was looking through it but couldnt find it Its actually a sport
31st Dec 2022 2:40pm |
Went for a drive.
31st Dec 2022 6:55pm |
It was the big hose with the intake temp sensor.
1st Jan 2023 4:11pm |
MuddyTDi Member Since: 13 Nov 2022 Location: Leeds Posts: 12 |
Who are you planning on using for the gearbox flush? |
2nd Jan 2023 6:37am |
The one, the only, Bodsy. Its actually a sport
2nd Jan 2023 8:31am |
