Home > Maintenance & Mods (L405) > Bl***y sidesteps again
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
These deployable sidesteps are really beginning to annoy me now!
They are now both out, when I open the car they do the little dance, coming out a bit further then ducking back a bit.
I’ve tried lubrication, to no avail.
Is it just a single module for both sides? Does anyone have the part number?
Ta 2017 (67) Vogue SE Corinthian Grey
Post #651466 22nd Dec 2022 5:46pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
LVPLGT0204 This is what you are after sits in the spare wheel area to the left. just looked at your profile and you are an SDV6 mine is an SDV8
Post #651469 22nd Dec 2022 6:18pm
Abacus405
Thanks for that.
Interestingly the same part number is for the deployable tow bar (which I also have), does it do both, or do I have two of the same modules? (I could swap them to test)
Post #651484 22nd Dec 2022 8:05pm
Tinman
Yes it does I was sent that one when I put steps on mine I also have a deployable tow bar
I still have the one I took off. as you say it's the same part number just one of the sockets is not used if you don't have deployables. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #651486 22nd Dec 2022 8:15pm
Abacus405
Pity you’re not closer to me, I could have borrowed your spare to see if that’s the problem. The only replacement I can find is £500 Shocked Shocked 2017 (67) Vogue SE Corinthian Grey
Post #651498 23rd Dec 2022 8:30am
Tinman
The cost from Duckworths is £262 approx and you may be able to return after if it doesn't fix it. Thumbs Up 2017 SDV8 4.4 silicon silver AB
Post #651504 23rd Dec 2022 9:22am
Abacus405
Thanks, duckworths price is £375 plus postage according to their website (VPLGT0204) 2017 (67) Vogue SE Corinthian Grey
Post #651521 23rd Dec 2022 10:49am
Purso
How old is your l405? Wondered how common the issue is?
Post #651531 23rd Dec 2022 11:12am
Abacus405
Mine is September 2017.
The module fits 17-19 models. 2017 (67) Vogue SE Corinthian Grey
Post #651539 23rd Dec 2022 12:05pm
Tinman
Hi sorry, it was £292.71 with a discount plus VAT as of 20/10/2022 try phoning to ask for Robin 2017 SDV8 4.4 silicon silver AB
Post #651540 23rd Dec 2022 12:06pm
Abacus405
Thanks Tinman 2017 (67) Vogue SE Corinthian Grey
Post #651545 23rd Dec 2022 2:13pm
are you sure its the module?
not an expert but could it be something as simple as needing a battery reset or corroded/loose connections ... - .- -.
Post #651548 23rd Dec 2022 2:31pm
Abacus405
To be honest I haven’t a clue! But because both sides are doing it and I haven’t got any other problems I thought it was probably the module. But the tow bar still works, so it’s not totally fried.
I think I may have to take it in somewhere. Or remove the steps. 2017 (67) Vogue SE Corinthian Grey
Post #651552 23rd Dec 2022 3:12pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I used to have have AMP power steps on my F150. They didn’t like the cold. I would just keep them in once the temp got around -10C. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #651556 23rd Dec 2022 3:45pm
JCW
My experience of deployable steps (L322 & L405) is if all the pivots are anything but completely lubricated & free to move, the anti-trap sensors kick in.
There are obvious points to lubricate (I use spray on white lithium grease using a long straw attachment) but theres another more hidden pivot point per bracket that’s higher & further in that’s more tricky to see / access.
That wouldn’t explain why both would simultaneously act up, unless both just needed more lubrication.
Post #651557 23rd Dec 2022 4:14pm
