![]() | Home > Technical (L322) > possibly frozen suspension |
razzer Member Since: 20 Feb 2015 Location: blackpool Posts: 54 ![]() ![]() ![]() |
hi all, during the cold spell we have just had i notice that my air suspension was a bit lumpy and noisy. now the mercury has risen it seems to be back to normal. has anyone had a problem with maybe water vapour freezing in the system and if so a remedy for this. thanks. |
MarkMurphy Member Since: 30 Oct 2022 Location: Cambridgeshire Posts: 16 ![]() ![]() ![]() |
Maybe the desiccant needs replacing, it dries out moisture in the system. |
thanks, i will look into it. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
It's in a receptacle attached to the pump, you can dry it out in an oven and reuse it, no need to replace... |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Well covered in W.M.
