Viscous fan issue code P0480-13 | |
Hi, I’m reposting as I’m not having great luck trying to to find answers. 2012 fullfatrr Sc
Previously posted by member but no resolution...
https://www.fullfatrr.com/forum/topic65249.html
Recently I got the “restricted performance” and the code is P0480-13 which indicated fan 1 open circuit. I checked fan (viscous) connections and fuse which is all good. Some research indicated fan replacement but I don’t want to replace unless necessary. Fan used to make a loud noise / roar on start up and driving but now it’s quiet and spins normal. Did the newspaper check and didn’t stop, temperature normal, cooling and heating is good.
Any suggestions?
