Home > Technical (L322) > '12 L322 4.4 V8 engine whining sound behind vacuum pump |
Tokyo Member Since: 27 Dec 2022 Location: Cork Posts: 1 |
My ‘12 L322 4.4 V8 has developed a whining sound on driver side behind the vacuum pump. Mechanic had a replacement vacuum pump fitted in order to rule it out. Noise is still there. No engine warnings
28th Dec 2022 9:34am |
Busarider Member Since: 17 Dec 2022 Location: Ontario Posts: 8 |
Sounds like the bearings on the water pump worn out. |
30th Dec 2022 3:42am |
