Home > General > Anyone having starting trouble with the cold?
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Considering the cold weather temperature, anyone had any trouble starting their fattys?
I started mine the other morning after 2 weeks of standing and showing -4c, turned key, wait for glow plug light to go out, repeated, fingers crossed, legs crossed and bingo fired straight up. The only worrying thing was I heard a slight knocking on start up and went after a few seconds, anything I should be worrying about? I take it, it's because it's been stood still and the oil has got a bit thick with the cold?
My missus fl2 td4 is struggling to start every morning, so bought some anti gel diesel additive to see if that will cure it. Could probably do with some new glow plugs.
Post #650891 16th Dec 2022 11:11am
JayGee
Mine started easily yesterday at -3 after being frozen for a week - no unusual sounds. Set the FBH going 10mins before from the bedroom window which warmed up the inside nicely before I got in. 2012 TDV8 Vogue (L322)
Post #650893 16th Dec 2022 11:21am
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
No trouble here. -10 yesterday and started the 4.2SC with no problems. Our FL2 finally killed it Yussa battery after 5 and a bit years yesterday though after a couple of HDC errors appeared and then it finally refused to turn it over. Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
Post #650898 16th Dec 2022 11:46am
Barmybrummie
My fbh doesn't work, maybe I should get that sorted at some point. I set the timer on night heater in my truck 2 hours before I start work, it's great to get into it being nice and warm and I don't have to scrape the ice off the windows.
You having problems with your fl2 as well then with the cold?
Post #650899 16th Dec 2022 11:51am
Superspoons
My FBH on my old 3.6TDV8 would only come on if a) it was cold enough and b) there was sufficient charge in the battery. As it has a parasitic drain at the time this meant it was off more times that it was used Sad
The FL2 has been a great car Very Happy - dare I say the most reliable LR product I've owned. Its just used consumables like the battery for instance. Maybe your glow-plugs need changing ? Gavin
Post #650900 16th Dec 2022 11:55am
gotters
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Santorini Black
I had a failed start the other day in -8c with no errors thrown on the Gap tool
Piecing it together I've been driving very short distances to the park to walk the dog, then back again, as the pavements have been impassable here this week (we had 17cm of snow in Essex) - I think what I've done with repeated freezing starts and a run of less than 5m is just drain the battery and not give it time to charge back up.
Put my jumper battery on it and started first time no problem, done a couple of slightly longer runs and can see the battery level via the Gap tool topping back up so don't think i've got a problem per se, just didn't use the car wisely in the conditions.
Will give it a slow trickle charge as soon as the warmer weather comes this weekend, didn't want to leave the charger out in this sub zero temps.
Post #650921 16th Dec 2022 3:58pm
mgrover
I had trouble before once or twice. Turns out the battery terminals were filthy. Quick clean with metal brush and away we get. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #651440 22nd Dec 2022 11:13am
p38arover
Australia
Yes, I've had to put a shirt and sandals on a couple of times when going out to the workshop at night lately. It's been as low as 17 deg C! Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #651441 22nd Dec 2022 11:42am
p38arover
Australia
It's funny what one gets used to. It's 2pm and 32 deg C (90 deg F) outside and it only feels warm, not at all hot. I think I prefer that to what you blokes have at the moment. Very Happy
45 deg C (113 deg F) is predicted over the Xmas break. That's hot. Sad Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #651581 24th Dec 2022 3:01am
johnboyairey
you think we have problems...
sound up....
&t=80s
Post #651584 24th Dec 2022 8:03am
cass
That's nowt a sniff of Easystart wouldn't sort !
Post #651592 24th Dec 2022 12:19pm
supershuttle
Mine had a funny turn, well I thought it was funny SWMBO was with me at the time she didn't see the funny side. Anyway we'd driven to the shopping centre and when we got back to the car I just got a ticking noise when I tried it to start it. So we went for lunch (Pizza Hut handy), I called out the RAC and arranged for a taxi home BUT when we got back to the car it just started - magic. So I cancelled the taxi and the RAC and we went hone - as a precaution I put the C-Tek on to make sure the battery was fully charged.
It's worth mentioning it was during the cold snap, so FBH, lights, heated seats and heated steering wheel were all on prior to the drive and the drive itself to the shops was only short (10 miles). I'd also restarted it a couple of times to park closer to the shops, SWMBO can't walk too far. In fact I've just applied for a Blue Badge for her but thats not relevant. Geoff
Post #651595 24th Dec 2022 1:51pm
p38arover
Australia
A few months ago (mid-winter), we we taking a week down south in the nation’s capital and the temp dropped overnight to near zero and when I tried to start the L322 - nothing. Not even moving the gear stick helped (it’s had this minor bug of needing that ever since I’ve owned it).
This happened a few of mornings in a row. I was perturbed as the starter motor had just been replaced with a new genuine unit and I was a few hundred km from home and the mechanics.
It came good when the temp warmed up and hasn’t given trouble since. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #651619 24th Dec 2022 11:06pm
