Home > Technical (L322) > Saggy Rear End 3.6 TDV8 2007 |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 393 |
Anyone? Not looking for a definitive answer just a bit of guidance based on others experiences.
21st Dec 2022 4:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35436 |
try using the search function... ... - .- -.
21st Dec 2022 4:21pm |
johnty Member Since: 05 Jun 2020 Location: Yorkshire Posts: 5 |
If you can't find a leak at the airbag , it can back leak through the valve block ( rear one is in o/s/r wheel arch . Off the top of my head the blue pipe is the air feed....if you take that off and leaks out of valve block then block is faulty.
22nd Dec 2022 6:20am |
Thank you Johnty, very much appreciate your useful contribution. Good information that I’ll follow up on.
22nd Dec 2022 9:34am |
