Home > Technical (L322) > Charging |
Simply put, the generator output is vehicle load+battery charge demand. There is a diagnostic chart on Topix that shows commanded generator output and the expected voltage range for that output, which may help. |
4th Dec 2022 5:35pm |
John-suusex Member Since: 31 Oct 2019 Location: Sussex Posts: 44 |
Thanks, trying get to the bottom of things.. 2008 TDv8 Vogue in Java black x2
4th Dec 2022 5:42pm |
Describe your concern, it may help you get the info you require. |
4th Dec 2022 5:43pm |
I was just trying to understand the scanner when it talks about command and load on these. 2008 TDv8 Vogue in Java black x2
4th Dec 2022 6:22pm |
Oh, well maybe read up the 'description & operation' section relating to charging in the workshop manual. It's quite comprehensive. |
4th Dec 2022 6:27pm |
Yes have been, though not really answered my questions. Just doing the home work..thanks 2008 TDv8 Vogue in Java black x2
4th Dec 2022 6:51pm |
