Home > Technical (L322) > Charging
John-suusex
Charging
Ok, so having a look at mine, could someone please explain how the Generator command and load work? When reading codes the command seems to be higher than the load.
Thanks 2008 TDv8 Vogue in Java black x2
2000 P38 They aren't all bad!
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #649838 4th Dec 2022 5:24pm
Phoenix
Simply put, the generator output is vehicle load+battery charge demand. There is a diagnostic chart on Topix that shows commanded generator output and the expected voltage range for that output, which may help.
Post #649840 4th Dec 2022 5:35pm
John-suusex
Thanks, trying get to the bottom of things.. 2008 TDv8 Vogue in Java black x2
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #649842 4th Dec 2022 5:42pm
Phoenix
Describe your concern, it may help you get the info you require.
Post #649843 4th Dec 2022 5:43pm
John-suusex
I was just trying to understand the scanner when it talks about command and load on these. 2008 TDv8 Vogue in Java black x2
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #649848 4th Dec 2022 6:22pm
Phoenix
Oh, well maybe read up the 'description & operation' section relating to charging in the workshop manual. It's quite comprehensive.
Post #649850 4th Dec 2022 6:27pm
John-suusex
Yes have been, though not really answered my questions. Just doing the home work..thanks 2008 TDv8 Vogue in Java black x2
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #649853 4th Dec 2022 6:51pm
