Home > Technical (L322) > Urgent help required
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Doing the torque converter on my 06 car , following a youtube guide that sats i need to unbolt the TC before pulling the box off , i cant find / see anything to undo ! Does the 06 box just slide off ???
Heeeelp !!
Post #649360 28th Nov 2022 3:35pm
blackpool
Hi Bembo
Have you looked at the workshop manual rather than YouTube ?
I think one is downloadable in the forum wiki or definitely available online.
Always best to read the source material rather than someones interpretation of it.
Post #649364 28th Nov 2022 4:13pm
GraemeS
The TC will be bolted to the flex plate that is the equivalent to a flywheel but the TC stays with the gearbox when the gearbox is removed. Other vehicles have an access hole that allows 1 bolt to be removed then the TC rotated to access the next bolt so I assume the same on your vehicle.
Post #649386 28th Nov 2022 7:51pm
