![]() | Home > Technical (L322) > Understanding my headlights. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2568 ![]() ![]() ![]() |
Have you checked if your fill-in bulbs are still halogens? |
Also bear in mind the seating position is very different, you can see more of the road & surroundings in a Range Rover, the average seating position in a German car is the equivalent of dragging your arrse along the ground like a dog with worms... |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 433 ![]() ![]() ![]() |
Do you mean my high beam bulb? The side lights etc I presume are standard bulbs. My build-sheet states ‘Xenon Headlamps [064CO]’… 2009 pre-facelift 3.6 TDV8. Last edited by KitTheRam on 2nd Dec 2022 10:31am. Edited 1 time in total |
Yes. I put the latest halogen bulbs in the cars (e30/e34/w124) which improved things but still not great, agree with the general positioning but still a decent view up, especially in my e34 touring. It was with the domed height on full beam I was like - wow, that’s good! Perhaps just me having such a vintage start point as mentioned. 2009 pre-facelift 3.6 TDV8. Last edited by KitTheRam on 2nd Dec 2022 5:47pm. Edited 1 time in total |
Looking at my lights I take it the main beam is xenon and the side lights are standard halogen, the high beam I am guessing is a very bright halogen bulb or is that also xenon? Is this generally the same set up on all 2007-2009 cars?
The Halogens are high-beam fill in to supplement the Bi-Xenons which are both dip & high beam by virtue of a movable shutter - see my 'HiD or LED' thread for info on upgrading the high beam halogens. The side lights (tungsten 'wedge' type) are in the lower outermost corner with the 35W Halogen 'cornering' fill-in lamps. |
Ah ok thanks. So high beam is produced by both main lenses but primarily from the xenon. May explain why it’s so effective. Can’t imagine how bright the latest led lights are on high beam in the new Range Rovers. 2009 pre-facelift 3.6 TDV8. |
Your fill-ins are still factory-style halogen globes. I replaced those in my MY12 with an HID kit which rather dramatically improved light output. |
Know there will be some dedicated threads on this but a simple question for now - is there wiring work to do or is the HID kit quite plug and play? As you can tell I’m quite happy with what I have but always happy to improve things. 2009 pre-facelift 3.6 TDV8. |
The HiD's I've been experimenting with have 'just worked', LED's on pre-2010 MY are problematic.
Thanks. Think I’ll stick to what I have as the novelty of seeing where I am going is enough for now! 2009 pre-facelift 3.6 TDV8. |
LASBAM Member Since: 04 Apr 2017 Location: Reutlingen Posts: 26 ![]() ![]() ![]() |
Hello together,
Thanks for the above. 2009 pre-facelift 3.6 TDV8. |
chdavis Member Since: 28 Nov 2021 Location: Washington DC Posts: 44 ![]() ![]() |
Very helpful! 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged 2020 Tesla Model 3 Performance, 2013 Mercedes-Benz G550, 2008 Ferrari F430, 2007 Volkswagen Touareg V10 TDI |
