Home > Technical (L322) > Understanding my headlights.
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Have to say, coming from a world of nineties headlights (various German marks) the difference in brightness is huge, guessing these are early xenon bulbs but in the scheme of things, on high beam especially, it’s a bigger improvement than I was expecting. Are L322’s known for good lighting of the road or is it merely the fact that my starting point is so vintage? My wife’s 09 civic isn’t too bad to be fair but the height, width and travel of the headlights on full beam surprised me. 2009 pre-facelift 3.6 TDV8.
Post #649664 2nd Dec 2022 1:03am
GraemeS
Have you checked if your fill-in bulbs are still halogens?
Post #649665 2nd Dec 2022 1:29am
Phoenix
Also bear in mind the seating position is very different, you can see more of the road & surroundings in a Range Rover, the average seating position in a German car is the equivalent of dragging your arrse along the ground like a dog with worms...
Post #649666 2nd Dec 2022 7:31am
KitTheRam
Do you mean my high beam bulb? The side lights etc I presume are standard bulbs. My build-sheet states ‘Xenon Headlamps [064CO]’… 2009 pre-facelift 3.6 TDV8.
Post #649673 2nd Dec 2022 10:21am
KitTheRam
Yes. I put the latest halogen bulbs in the cars (e30/e34/w124) which improved things but still not great, agree with the general positioning but still a decent view up, especially in my e34 touring. It was with the domed height on full beam I was like - wow, that’s good! Perhaps just me having such a vintage start point as mentioned. 2009 pre-facelift 3.6 TDV8.
Post #649674 2nd Dec 2022 10:29am
KitTheRam
Looking at my lights I take it the main beam is xenon and the side lights are standard halogen, the high beam I am guessing is a very bright halogen bulb or is that also xenon? Is this generally the same set up on all 2007-2009 cars?
Post #649709 2nd Dec 2022 5:44pm
Phoenix
The Halogens are high-beam fill in to supplement the Bi-Xenons which are both dip & high beam by virtue of a movable shutter - see my 'HiD or LED' thread for info on upgrading the high beam halogens. The side lights (tungsten 'wedge' type) are in the lower outermost corner with the 35W Halogen 'cornering' fill-in lamps.
Post #649710 2nd Dec 2022 5:53pm
KitTheRam
Ah ok thanks. So high beam is produced by both main lenses but primarily from the xenon. May explain why it’s so effective. Can’t imagine how bright the latest led lights are on high beam in the new Range Rovers. 2009 pre-facelift 3.6 TDV8.
Post #649711 2nd Dec 2022 5:56pm
GraemeS
Your fill-ins are still factory-style halogen globes. I replaced those in my MY12 with an HID kit which rather dramatically improved light output.
Post #649720 2nd Dec 2022 8:39pm
KitTheRam
Know there will be some dedicated threads on this but a simple question for now - is there wiring work to do or is the HID kit quite plug and play? As you can tell I’m quite happy with what I have but always happy to improve things. 2009 pre-facelift 3.6 TDV8.
Post #649722 2nd Dec 2022 9:06pm
Phoenix
The HiD's I've been experimenting with have 'just worked', LED's on pre-2010 MY are problematic.
There is more involved with getting the electronics into the headlight assembly with the HiD's but it's not by any means difficult.
I'm intending to re-align the high beam fill-in reflectors but it's by no means a 'must do'.
Post #649723 2nd Dec 2022 9:09pm
KitTheRam
Thanks. Think I’ll stick to what I have as the novelty of seeing where I am going is enough for now! 2009 pre-facelift 3.6 TDV8.
Post #649731 3rd Dec 2022 12:09am
LASBAM
Germany 2007 Range Rover Vogue TDV8 Orkney Grey
Hello together,
L322 Bi-Xenon Lamp
Low-Beam and High Beam = 35W D3S Xenon-Bulb (Mechanical shutter and Projection System)
additional High Beam Spot = Bulb (Bulb and Reflection System)
All 35W Xenon are required to have a Outer Lens Washing System, for the 25W Xenon Systems it is not necessary.
Also all 35W Xenon require a automated Leveling. This is done via a manual stepper engine in the headlamp.
The heigh measurements for the HL are generated by the body leveling sensors of the car (same as in for the ESP System).
For the higher performant LED ADB ("Matrix") Systems nowadays, there is also a leveling by stepper engine needed - at the moment same systematic as for the 35 Xenon. Current:
- 2006 RR L322 - 3.6 TDV8
- 2022 MB AMG GT BS
- 2020 Audi Q2
Past:
- Ferrari California 30
- 2018 Abarth 595 Competizione
- 2009 Porsche Cayenne Diesel
- 2010 MB E500 Coupé
- 2005 Porsche 996 Turbo
- 2002 Porsche Boxster 986 S
- 2001 Audi S8
Post #649813 4th Dec 2022 12:35pm
KitTheRam
Thanks for the above. 2009 pre-facelift 3.6 TDV8.
Post #649817 4th Dec 2022 1:24pm
chdavis
2012 Range Rover Autobiography 5.0 SC V8 Galway Green
LASBAM wrote:
Hello together,
L322 Bi-Xenon Lamp
Very helpful! 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
2020 Tesla Model 3 Performance, 2013 Mercedes-Benz G550, 2008 Ferrari F430, 2007 Volkswagen Touareg V10 TDI
Post #652014 30th Dec 2022 5:47am
