Home > Technical (L322) > 10 years maintenance (Front dismantled)
Page 3 of 5 <12345>
shinchan
Spain
Removed the differential and preparing to paint...
to work comfortably I screwed it to a pallet...
primed and ready to paint
Post #650183 8th Dec 2022 6:38pm
shinchan
Spain
waiting to have everything ready and take them to sandblasting and plating...
Post #650185 8th Dec 2022 6:44pm
shinchan
Spain
Haylands wrote:
You're doing an excellent job, will be better than new soon... Thumbs Up Bow down Thumbs Up
THANKS!!
Post #650186 8th Dec 2022 6:46pm
shinchan
Spain
GGDR wrote:
shinchan this is amazing
THANKS!!
Post #650187 8th Dec 2022 6:46pm
shinchan
Spain
MarkMurphy wrote:
Very good eye for detail, i need a garage, haha.
THANKS!!
Post #650188 8th Dec 2022 6:47pm
shinchan
Spain
The transmission pan too much rusted inside...thinking in make some hole drains! What do you think about?
After sandblasted I´ll consider to powder coat instead raw.
Post #650189 8th Dec 2022 6:56pm
Jayk69
While you have it in bits consider a new alternator!! my car has covered 130k and alternator failed yesterday Censored i nearly replaced it when i had the front end off doing all belts and pullies but it tested fine!!
new Denso unit is on it's way!!
But i do not have time to fit it so it is off to local garage!! 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #650271 9th Dec 2022 11:53am
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Jayk69….I am changing my alternator tomorrow hopefully. I am not looking forward to it.
Post #650274 9th Dec 2022 12:37pm
kevinp
My tip is when you slide the alternator out make a note of the position of the wire before you disconnect it.
Post #650284 9th Dec 2022 1:18pm
philip1972
Good tip, cheers
Post #650291 9th Dec 2022 3:46pm
shinchan
Spain
Understood! Just ordered a new alternator! Thanks!!
Post #650348 10th Dec 2022 8:14am
shinchan
Spain
Just for fun, a touch of British green underneath...
Post #650368 10th Dec 2022 11:15am
You should paint it dark brown, the oil leaks won't show.... Whistle Pete
Post #650399 10th Dec 2022 5:14pm
Jayk69
Sinchan, i did my belts and pullies 18 months ago, i also changed the water pump as it was in bits and seemed like a good idea as these can go when changing to new belts and tensioners. Since i have done that my AC compressor failed in spring this year and as you already know my alternator failed this winter. the AC compressor is a simple fix there is an electric valve in the back of it. this is cheap to replace and i would also recommend replacing it while you car is in bits. I will try to find a link on hear that explains it. You cannot replace this valve with the compressor in place it has to come out, which is why i replaced the whole thing. had i know all this when i did my belts i would have changed the valve at that point. Keep up the good work Thumbs Up 2012 Vogue 4.4 TDV8 - Current
Post #651101 19th Dec 2022 10:11am
Jayk69
Sinchan here is the thread https://www.fullfatrr.com/forum/topic43778.html?highlight=air+con 2012 Vogue 4.4 TDV8 - Current
Post #651110 19th Dec 2022 11:32am
Page 3 of 5 <12345>
