Home > Technical (L322) > 10 years maintenance (Front dismantled) |
shinchan Member Since: 05 May 2015 Location: santiago de compostela Posts: 109 |
waiting to have everything ready and take them to sandblasting and plating...
8th Dec 2022 6:44pm |
THANKS!! |
8th Dec 2022 6:46pm |
THANKS!! |
THANKS!! |
8th Dec 2022 6:47pm |
The transmission pan too much rusted inside...thinking in make some hole drains! What do you think about?
8th Dec 2022 6:56pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
While you have it in bits consider a new alternator!! my car has covered 130k and alternator failed yesterday i nearly replaced it when i had the front end off doing all belts and pullies but it tested fine!!
9th Dec 2022 11:53am |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 |
Jayk69….I am changing my alternator tomorrow hopefully. I am not looking forward to it. |
9th Dec 2022 12:37pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1222 |
My tip is when you slide the alternator out make a note of the position of the wire before you disconnect it. |
9th Dec 2022 1:18pm |
Good tip, cheers |
9th Dec 2022 3:46pm |
Understood! Just ordered a new alternator! Thanks!! |
10th Dec 2022 8:14am |
Just for fun, a touch of British green underneath...
10th Dec 2022 11:15am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
You should paint it dark brown, the oil leaks won't show.... Pete
10th Dec 2022 5:14pm |
Sinchan, i did my belts and pullies 18 months ago, i also changed the water pump as it was in bits and seemed like a good idea as these can go when changing to new belts and tensioners. Since i have done that my AC compressor failed in spring this year and as you already know my alternator failed this winter. the AC compressor is a simple fix there is an electric valve in the back of it. this is cheap to replace and i would also recommend replacing it while you car is in bits. I will try to find a link on hear that explains it. You cannot replace this valve with the compressor in place it has to come out, which is why i replaced the whole thing. had i know all this when i did my belts i would have changed the valve at that point. Keep up the good work 2012 Vogue 4.4 TDV8 - Current 2014 Navara V6 - Gone 2004 Vogue TD6 - Gone Grand Cherokee - Gone Discovery V8 (LPG) - Gone Discovery TD5 - Gone |
19th Dec 2022 10:11am |
Sinchan here is the thread https://www.fullfatrr.com/forum/topic43778.html?highlight=air+con 2012 Vogue 4.4 TDV8 - Current
19th Dec 2022 11:32am |
