Home > Maintenance & Mods (L322) > Near Side Rear Hub Upper Bush Part No Needed
pcourtney
just had a "Health Check" at main dealer, and they came back with
n/s/r hub upper Bush has excessive play and requires a new bush on my TDV8 2011
would anyone know the part number I have to buy ??
is it this one below
Post #647914 11th Nov 2022 7:49pm
That looks like the one, I always get a new bolt and nut as well, they can seize in... Thumbs Up Pete
Post #647915 11th Nov 2022 7:52pm
pcourtney
it looks like Part Number RHF000260
can anyone confirm for me please
Post #647919 11th Nov 2022 8:25pm
kevinp
That is the correct number. You will need a bush puller though to get it out and back in.
Post #647922 11th Nov 2022 8:47pm
Strider
Thumbs Up Also before you start soak area with "Plus-Gas" day before. That stuff is light years ahead of WD40.
I used this tool when I did mine:
https://www.ebay.co.uk/itm/134142756228?mk...ohAAAAAA..
Other people have used sockets of a suitable size and some
studding. Haylands is right about the bolts, mine were very rusty and had to be hammered out with a club hammer
and a lot of swearing Smile
Post #647955 12th Nov 2022 1:33pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Buy original as pattern parts are known to be a millimetre too small and they will slide out. You can extract them by using a deep socket and all-thread.
Easy job to do. Thumbs Up
Post #647966 12th Nov 2022 6:10pm
pcourtney
I have some Plus Gas, so will start spraying tomorrow - thanks for reminding me Smile
£75 quid for the bush remover, is the tool just for the Upper Bushes" - or will it come in handy for any other bushes on the car ?
otherwise I think I will go down the "Deep Socket" and Studding route !
Post #647970 12th Nov 2022 7:40pm
Strider
Hi,
Sadly yes, the kit is just for the upper ones. I bought the kit for the lower ones at the same time (about the same price).
Thats my next job, got advisories on the MOT this month, was shown there is slight movement on both lower ones.
I forgot to mention I coated the bolt shaft with copper grease when I assembled it.
Good luck with yours Thumbs Up
Post #647978 12th Nov 2022 10:33pm
dhallworth
This bush can be done quite easily without a bush puller tool.
https://www.fullfatrr.com/forum/topic27263.html
Post #647999 13th Nov 2022 6:12pm
pcourtney
David - thx for that - really good guide that - will now tackle it myself using that guide Smile
Post #648000 13th Nov 2022 6:30pm
dhallworth
I can’t take credit for the guide but it’s well written and well photographed.
Post #648001 13th Nov 2022 6:47pm
