Home > Wheels & Tyres > 285 50 20 tyres
Jamie K
United Kingdom 2002 Range Rover Vogue Td6 Baltic Blue
285 50 20 tyres
Hi guys. I'm currently running 255/55/20 on my 02 l322, I need new tyres and have been offered some 285/50/20, my question is if I fit these will there be any rubbing or other adverse effects?
Post #647784 9th Nov 2022 7:27pm
JMC
Very little difference in the height of the tyres (5mm), but a full 30mm wider with the 285's.
Providing the wheels can cope with the width, I suspect there won't be any rubbing issues. Just turn the wheels to full lock and see if there's 15mm left to spare! Wink
Won't affect the speedo either. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #647787 9th Nov 2022 8:44pm
Vogue
I have this size on my L405, they fit fine but they are a lot bigger in width and height. Ignore the generic on line calculators as they are not representative of actual true sizes and only give a very rough indication - I also have a set of 22” Turbines and a set of New Cooper 285/50/20 AT’s are 10mm dia more than standard fit Continental 275/40/22. These are accurate sizes measured side by side with a straight edge / level from ground level and are accurate measurements.
No issues at all with rubbing 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #647792 9th Nov 2022 10:26pm
GraemeS
Australia
Note that the L405's standard tyre diamater is 31" whereas the L322's is 30" so fitting comparison between the 2 vehicles isn't valid.
Post #647793 10th Nov 2022 12:24am
TJNZ
New Zealand 2017 Range Rover Autobiography SDV8 Carpathian Grey
I am going thru a similar process at the moment. I have 22inch turbines with Continentals Cross 275/40/20 Cross Contact XL's on currently. Intend to keep these.
I have just secured some 2nd hand 20inch LR alloys off a 2015 RRS and intend to fit some AT's. After trawling thru the forums and looking at pictures I think my sizing preference is 285/50/20. My only question is will these fit on an 8.5J rim? From what I can see I think (?) these should fit in the spare wheel well.
Any knowledge on this appreciated. 2017 L405 AB SDV8
2011 L322 Vogue SE 4.4 TDV8
Post #681962 6th Jan 2024 10:20am
TJNZ
Landed on the 285 50 20 Falken Wildpeaks. Here is what the comparison is to the 22 inch rims with the 275 40 22 Contis on the factory turbines. Early days but happy so far. Just got to find a spare Very Happy
[/img] 2017 L405 AB SDV8
Post #685174 9th Feb 2024 11:42am
SeldomSeenKid
Scotland 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Re: 285 50 20 tyres
My 07 SC came with 285/35R22 and there was plenty of clearance.
I'm now running 275/45R20s. ---------------------------------
2008 L322 Supercharged
2007 Porsche 987 Boxster S
2024 BMW iX3
Post #685176 9th Feb 2024 12:08pm
