![]() | Home > Wheels & Tyres > 285 50 20 tyres |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 780 ![]() ![]() ![]() |
Very little difference in the height of the tyres (5mm), but a full 30mm wider with the 285's.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3785 ![]() ![]() |
I have this size on my L405, they fit fine but they are a lot bigger in width and height. Ignore the generic on line calculators as they are not representative of actual true sizes and only give a very rough indication - I also have a set of 22” Turbines and a set of New Cooper 285/50/20 AT’s are 10mm dia more than standard fit Continental 275/40/22. These are accurate sizes measured side by side with a straight edge / level from ground level and are accurate measurements.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2644 ![]() ![]() |
Note that the L405's standard tyre diamater is 31" whereas the L322's is 30" so fitting comparison between the 2 vehicles isn't valid. |
TJNZ Member Since: 17 Apr 2022 Location: Auckland Posts: 19 ![]() ![]() ![]() |
I am going thru a similar process at the moment. I have 22inch turbines with Continentals Cross 275/40/20 Cross Contact XL's on currently. Intend to keep these.
Landed on the 285 50 20 Falken Wildpeaks. Here is what the comparison is to the 22 inch rims with the 275 40 22 Contis on the factory turbines. Early days but happy so far. Just got to find a spare |
SeldomSeenKid Member Since: 24 Jan 2024 Location: Glasgow Posts: 75 ![]() ![]() ![]() |
My 07 SC came with 285/35R22 and there was plenty of clearance. I'm now running 275/45R20s. --------------------------------- 2008 L322 Supercharged 2007 Porsche 987 Boxster S 2024 BMW iX3 |
